Changing 350 Tune Port to 400 small Block?
Old Aug 31, 2008 | 06:58 PM
PrdnJoy's Avatar
Car: 89 Firebird Formula
I am thinking of changing my 350 to a 400 small block bored 30 over to a 406 ci with edelbrock aluminum heads edelbrock aluminum 2-4 intake with 2 edelbrock performer carbs. And a healthy cam this engine is currently in a car that turns high 10s in the quarter .
I would like any and all opinions on this as I am being told it will be easier to work on and run 100% better and make the engine compartment look alot cleaner....
I guess my question is if you were offered by someone to do this would you take this option and change motors?
Old Aug 31, 2008 | 08:20 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Changing 350 Tune Port to 400 small Block?
It won't be any easier to work on, run any better, or make the engine compartment look any cleaner than any other small block.
If you do decide to do the swap, forget about the dual carbs.
Old Sep 1, 2008 | 10:58 AM
PrdnJoy's Avatar
Other opinions would be GREATLY appretiated......Pros and Cons would be nice.....
Old Sep 1, 2008 | 11:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Dual quads is pre-school, not even old-school. If you're after show and want something sticking through the hood, go for it. If you're after go, get a Performer RPM Air Gap and Holley 750 DP.
Which Edelbrock heads? Do you have more specifics on the cam? What transmission are you going to run? Rear end? Is the rest of the car ready for this much power?
Driveability and fuel economy will surely suffer. What are your plans for use of the car?
Old Sep 5, 2008 | 08:58 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
You can do a carb setup on the eng. thats in the car.
If you got the parts and a way to bring the car to me,I can make it happen.
I personally would leave the tpi on the car.
You're not having any problems with the ecm I sold you 6 months ago are you?
Why would you want to change the eng. setup on a beautiful car like that?
Old Sep 6, 2008 | 11:35 AM
PrdnJoy's Avatar
Why would you want to change the eng. setup on a beautiful car like that? Thank You..
I am NOT having any problems with the ECM unit the car is running like a charm (Thank You) I have had no problems since it was installed other then a couple weeks ago my radiator called it quits but that has been replaced but after almost 20yrs I can handle that.
As for me posting this post on engine swap I did it because I was offered a motor to put into my car that would do away with all the computer questions or repairs that NO ONE (other then Frank the guy that put in your ECM unit) knows what they are doing down here even the dealers screw it up.They figure it would be a less burden and if something were to go wrong it could be fixed they can handle the older engins were all the wiring and computer problems they don't know were to start.
You know my car means alot to me and I myself am VERY leary of this swap but I thought I would throw it out there for suggestions before my final decission..
~P.S~ By the way did we go to all Black in your Ride???
Have you done anymore to yours ????
Old Sep 7, 2008 | 05:23 AM
I would leave the eng. like it is.Just my opinion though.
Actually,I am in the process of building a corvette l98 to replace my old 305.
And no,interior is still grey/black.
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
camaro71633
Sep 1, 2015 10:24 AM
Jake_92RS
Aug 11, 2015 10:39 AM
