Best fuel pump for the $$
Old Sep 1, 2008 | 04:39 PM
87_GTA_5.7's Avatar
Car: 1987 Pontiac GTA Trans Am
Engine: Basic Stroked SBC..383
Transmission: PerformaBuilt 700R4 3000 Stall
Axle/Gears: Moser 9in. 3:70s
Its time to get fuel to my new engine. I just did a TPI to 386 carb swap on my 87 GTA. This is my plan let me know if it sounds good...Im going to get a new gas tank and weld in a sump kit. Then have an extrenal elctric pump, and reg. But I dont know what is the best one to buy for my motor. Thats the plan but if someone has a better idea..please tell me because Im lost of how Im going to make it work..
Old Sep 1, 2008 | 10:16 PM
3833rdGen's Avatar
Car: 91 Camaro
Engine: 383
Transmission: Turbo 350
Axle/Gears: Ford 9" 4.56 gear w/spool
Re: Best fuel pump for the $$
The Holly Blue is a great fuel pump
Old Sep 2, 2008 | 07:48 AM
87_GTA_5.7's Avatar
does my plan sound like a winner or is the a better way...
Old Sep 4, 2008 | 06:37 PM
3833rdGen's Avatar
Car: 91 Camaro
Engine: 383
the sump kit sounds fine, you want to put a filter on your line before the pump and if your using a return line you need a bypass regulator to run it back to the tank. the regulator i used was the Holly 12-803 BP
Old Sep 4, 2008 | 06:59 PM
87_GTA_5.7's Avatar
Can someone point me or tell me how to make an after market fuel gauge work. Im building an Auto Meter dash and need to know what to get to make it work with what im doing in the tank..
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
