SBC serpentine on BBC?
Car: 92 Rs
Engine: 4 Bolt "010" 383
Transmission: 700R4 trans brake Hughes 3K convert
Axle/Gears: BW 9Bolt 3.70's
ok, i DID search and im getting jumbled answers.
can i swap the serp. setup off the sb in the my 92 onto a BBC? or is that a no go?
it will have the A/C delete pully kit and the Air Pump Delete Kit installed as well....
any help would be awesome.
Transmission: 4L80E/4L80E
The alternator, PS pump, and AC compressor, maybe, but not the brackets or water pump.
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Re: SBC serpentine on BBC?
MAybe you meant multi rib(alternator, wp and crank)..Yes it will fit..Stock brackets even..Its the ps steering that needed work
If you meant the single belt serpentine then no it wont fit.
Car: 92 Rs
yea guys sorry for not being clear, i did mean the single belt setup that runs all the accessories.
ok cool, i figured it wouldnt work.
hopefully i can find a parts truck w/ a big block in it and use the accesories off it and the brackets.
thanks
Luke
thanks
Luke
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
As long as all the pulleys are in line, you can mix and match whatever you want. The hardest part is getting things like the alternator and PS pump lined up since the mounting brackets are not usually the same.
gixxer92
May 18, 2017 11:20 AM
darwinprice
17
Oct 11, 2015 11:51 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
