distributor and coil
Old Oct 6, 2008 | 09:12 PM
Jesse's87Z28's Avatar
im putting a 350 into my305 tpi motor im swapping the tpi onto the 350 will the distributor and coil work fine from the 350 or will i need to swap mine from the 305? Thanks for the info!!!
Old Oct 6, 2008 | 09:22 PM
Z28baynard's Avatar
Car: 1987 camaro z28
Axle/Gears: ??
Re: distributor and coil
hi it should be ok to keep the same distributor but i will say that i also changed from a 305 to a 350 and i just bought a new HEI 65000 distributor cheap and it helps the car respond better
Old Oct 6, 2008 | 09:28 PM
Thanks man i appreciate the info!! I dont have the 350 home yet so i cant compare yet just tring to get as ready as i can so putting the motor in goes smooth and QUICK! Thanks!
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
Damon
Sep 26, 2015 04:29 PM
