small block 350 power/performance
Old Oct 21, 2008 | 09:27 AM
chevymansmp790's Avatar
i bought a older 350 and i am putting some money into it to give it more power just so i can be content with it till i can get a latermodel motor.
i am planing on doing a nice cam, intake, heads, carb, dist. long tubes, i just wanted ask around what other poepl have done or what u have used to get an old 350 to perform good and be content with it. i dont want to get into bottom end just because of that fact this motor is only getting me by.
Old Oct 21, 2008 | 11:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There really isn't much difference between building an older vs. newer 350 except flat tappet vs. roller lifter cam, and that's not a big factor.
If you aren't willing to go through the bottom end, you'd better keep it a mild build. What are you willing to spend? You can get a good Vortec heads/intake/gasket/bolts/rockers kit from sdparts.com for around $1100. Add a cam like Comp XE262, 650 DP holley, you'll have a decent performing driver.
theshackle
Mar 5, 2017 06:37 PM
Mickeyruder
Sep 2, 2015 02:45 PM
camaro71633
Sep 1, 2015 10:24 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
theurge
Aug 21, 2015 12:46 PM
