what kind of power am i looking at
Car: 2000 TRANS AM
Engine: H,C,I LS1
Axle/Gears: 3.42 posi
i know its not a fbody but this form is really helpful
i have a 1990 s10 with a 350 from a 78 impala and 373 posi
the motor came with 170hp and about 250trq. so what i wanna know is what would i be looking at for hp/trq if i added 2.02 heads, .488 lift cam, rpm intake. and a 650 edelbrock.
so with that a TH350 and 373 posi. what do you think i wll be putting down. and if some one has any clue of a 1/4 mile time?
thanks alot guys. and i do still have my firebird. but this s10 is my project with my dad.
Transmission: 4L80E/4L80E
Insufficient information. The typical "2.02 heads" are 882 boat anchors. No different than what your '78 350 engine had, just bigger valves that don't help a lick with flow.
Give us casting #'s, that would be real information.
Or, just do Vortec heads.
Again, insufficient information. Need duration, LSA #'s.
Why?
Why?
Car: 2000 TRANS AM
Engine: H,C,I LS1
Re: what kind of power am i looking at
the carb is what i got to work with.
i only know the lift of the cam b/c it came out of my dads vega.
the heads are 2.02 by 1.60 with 67cc chambers
On Probation
Engine: several
Transmission: none
Axle/Gears: none
As an automotive machinist who has done countless 350s, let me make some assumptions. One, the heads are World S/R Torquers, Not great, but you could see 375 HP. Reusing a cam, but in a different block, means buying new lifters. I assume it's a common, old-tech, generic, with 234 duration at fifty. And a lobe sep of 112. For what you propose to do, I'd say it'll turn 6000 rpm, and I'd advise starting with a 2400 stall torque converter.
Car: 2000 TRANS AM
Engine: H,C,I LS1
i know the cams made by crane cams.
i know i need new lifters.
heads come back tomorrow so ill get the cast numbers.
so your saying around 300hp???
how do i find out what the cams lift,duration, and lope is? i have it in the garage so i can go look at it if needed.
thanks alot guys
thanks alot guys
sailtexas186548
Aug 24, 2015 10:11 PM
novaderrik
Aug 10, 2015 12:44 PM
