power steering bracket....
Old Dec 3, 2008 | 04:06 PM
86 z28 350's Avatar
ok i swapped a 350 out of an 84 corvette into my 86 Z, and then i put long tube headers on it. now i went to put all my camaro accesories onto the vette engine and my power steering bracket bolts to my stock manifold. does anyone know where i can buy a new bracket that bolts to the block instead?
Old Dec 3, 2008 | 04:46 PM
TheBigJ's Avatar
Car: 85 Firebird
Engine: SBC 383/88BW
Transmission: Built 700R4
Axle/Gears: Moser 9in/3.55
Re: power steering bracket....
I am in the same boat and it just looks weird with headers and the brackets just sticking out... I am going to use spacers and just buy new bolts to fix everything.
Old Dec 3, 2008 | 04:57 PM
Twin_Turbo's Avatar
Might want to try a C4 corvette bracket. Does your car have a serpentine setup? If so, C4s also have that. More importantly, they come factory with shorty headers so no log manifolds with a big bracket bolted to them.
Old Dec 3, 2008 | 05:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
An '86 didn't come with serpentine from the factory.
Just cut off one leg of the bracket that originally bolted to the manifold. Use a spacer to duplicate the original distance from the head to outer manifold and an original manifold bolt/stud for the bracket.
See Fig A from these Hooker instructions. http://static.summitracing.com/globa...ok-2460hkr.pdf
Old Dec 3, 2008 | 10:54 PM
86 z28 350's Avatar
alright ill look intothat tomorow after i get out of class.. also one more thing, has anyone had trouble with there headers being really close to the subframe? i have flowtech ceramic coated headers, and with them bolted on i cant even move the thing the collector bolts to.
Old Dec 11, 2008 | 10:20 PM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
i had the problem with the headers being close to the frame on my swap. I also had new motor mounts and after the engine ran for a few miles, it must have just settle cause now it has more room. If you have poly motor mounts try switching to rubber, that also helped me out.
Squeaky8791
Feb 5, 2020 08:29 PM
Vintageracer
Jan 10, 2020 05:33 PM
Chuck84TA
Jul 15, 2016 09:05 PM
evilstuie
Apr 14, 2016 08:52 PM
deracer
Apr 11, 2016 12:04 AM
