Crate Motor Recommendatin 1991 GTA
Old Dec 26, 2008 | 02:13 PM
ranger1991gta's Avatar
The 305 in my nice 1991 GTA is getting tired. What current GM performance crate motor will work under the TPI that I have given a change to 350 adn larger injectors, right PROM, etc......I cannot find any reliable info on this...thank you Todd
Old Dec 26, 2008 | 02:33 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Crate Motor Recommendatin 1991 GTA
I really think a new Vortec GM 350 is the best you can get for a stock TPI swap or upgrade.
http://www.sdpc2000.com/product/1253...er8500GVW.aspx
Compared to other crate engines, it really is great. The only other thing you need that I know of is the vortec TPI base since the heads have a different intake bolt pattern. Vortec heads seem to really complement TPI setups in stock form.
http://www.sdpc2000.com/product/SD38...Baseplate.aspx
Old Dec 26, 2008 | 02:36 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
There arent any GMPP crate engines that are a direct bolt in for a TPI engine. The ZZ4 engine is a close match but the heads are the Corvette L98's and have their own problems. (search for more info)
I'd recommend a short block and then get your own heads, cam, and intake.
jhawkeye
May 25, 2022 06:33 PM
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
italiano67
Dec 11, 2016 09:21 AM
Steve78LT
Feb 24, 2016 12:15 AM
