305-350 ecm question
Old Jan 13, 2009 | 11:13 AM
Z28Camaro83's Avatar
Car: 1983 Z28 Camaro
Engine: 5.0L 305 TPI
Hello all,
I recently swapped a 350 into the place of my worn out 305 TBI. All of the goodies from the 305 swapped right over. I got the new injectors, knock sensor, all that good stuff. I am having a hard time finding the correct ecm. I have read some were taking one out of a 1987 caprice ending in 8746 for the service number.
Where would I find this ecm? It seems to be the key to my success and turning out to be a brain buster! Thanks you guys!
Old Jan 22, 2009 | 02:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I don't know the answer to your question, but I'd suggest looking on the TBI forum. And, now you've got a bump in case someone here knows the answer.
Old Jan 22, 2009 | 03:15 PM
David 91RS/Z28's Avatar
Re: 305-350 ecm question
If your still using the TBI injection, just swap the engine over and have a custom chip burned. No reason to need a different computer.
Old Jan 24, 2009 | 02:59 PM
ProtoMaster22's Avatar
Car: 92 Camaro RS
Engine: Vortec TPI 412
Axle/Gears: BorgWarner 327 Limited Slip
did you use the stock cam out of the 305 when you swaped it over or did you change it?
ezobens
Aug 19, 2015 10:29 PM
355tpipickup
Aug 19, 2015 10:02 PM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 10, 2015 08:42 AM
