After Market balancer
Old Feb 18, 2009 | 03:53 PM
Jonathan Dyer's Avatar
Car: '83 Berlinetta
Engine: 383 CI
Axle/Gears: 3.73, Eibachs, Tokiko Illuminas,
Hello. I recently purchased a GM crate engine. To my surprise it is equipped with a much upgraded balancer that has degree marks etched on the surface.
I also have a new "Professional Products" balancer that is black with white marks that is much easier to read.
Would the after market balancer in any way be a downgrade from what GM put on the engine? Would I be foolish to swap them?
Thanks,
Jon
JSD MOD 02/17/09
Old Feb 18, 2009 | 10:37 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: After Market balancer
Personal preference. As long as they're the same diameter and the TDC timing mark is in the same location (usually directly over the keyway) then you can use the one you like the best. This is also assuming it's a 350 and uses a neutral balanced dampener. If it's a 383/400+ and needs an externally balanced dampener, you can't use a neutrally balanced one.
Old Feb 19, 2009 | 12:45 AM
Car: '83 Berlinetta
Engine: 383 CI
OK, Thanks. Yeah, it's a 383. I hadn't given any thought to the displacement making a difference. I think I'll return it and just rub some tire chalk into the markings on the GM one to make them stand out.
Thanks,
Jon
Old Feb 19, 2009 | 09:50 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's not the displacement that makes a difference, it's the way the rotating assembly is balanced.
Is this a GM 383, or a 383 SBC from somebody who builds crate engines?
Most likely it's an externally balanced engine, and therefore your internally balanced 350 damper will not work.
Old Feb 19, 2009 | 01:31 PM
Car: '83 Berlinetta
Engine: 383 CI
Yes, it's a GM zz383.
Jon
Old Feb 19, 2009 | 02:50 PM
five7kid's Avatar
Use the damper that came on the engine.
You can do a wipe painting of the marks if you like.
Old Feb 20, 2009 | 07:52 AM
Car: '83 Berlinetta
Engine: 383 CI
Good idea!
Jon
1992Z28!
Nov 19, 2015 07:33 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
monte87cortez
Sep 26, 2015 08:10 PM
Magman
Sep 13, 2015 12:14 AM
