Is this worth it?
Old Mar 25, 2009 | 10:12 AM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
Is this worth it?
Actually before I ask if its worth it..will it work?. Small block 350 so it will bolt in my car. Currently my car is a tpi. Would I be able to convert these heads to adapt to my intake? or do i not have a choice other than to carb it. Oh. and im not worried about passing emissions.
NEW HI TECH PERFORMANCE ENGINE -
part no ch350pc05 power crate roller cam cast iron heads 400 hp 445 torque engine specifications · · · · · · · · · · · · · horsepower torque balanced bore x stroke compression ratio recommended fuel maximum rec rpm block crankshaft pistons connecting rods rockers camshaft lift intake/exhaust w/1.6 dur .050 int exh · cylinder heads · manifold · warranty 415 440 dynamically 4.03 x 3.48 9.5:1 92 octane 5,800 4 bolt iron iron hyper cast forged pm 1.6:1 hyd roller .525 525 218°/228° ported vortec air flow dual plane 1 year windyntm superflow corp.©2000 test 1133 engine details air-flow dual plane aluminum manifold super duty valve springs and valves hi-tensile fasteners large vavles 2.02 intake and 1.6 exhaust moly faced ring set 100 live tested with sheetmetal monster horsepower and torque for a 350 muscle car style lopey idle dyno tested with 850 cfm carb 1 5/8 primary tube headers 35º total timing cranking pressure 160 psi 12 inches of vacuum at 800 rpm must use melonized steel distributor gear not legal for sale on pollution controlled motorized vehicles boats or equipment specifications subject to change without notice engine supplied with black valve covers and balancer 6
Hes asking $2000 for this. Thanks. See pic
Old Mar 25, 2009 | 10:14 AM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Re: Is this worth it?
Heres the sheet
Attached Thumbnails Is this worth it?-normal_performance-crate-engines-000010.jpg
Old Mar 25, 2009 | 12:09 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
You're gonna need to call SDPC for their TPI base for Vortec heads. Using this, with Edelbrock TPI runners and a ported plenum, you'll be around 365 horses. This is very similar to an engine package SDPC already offers. Price ($2000) isn't too bad, maybe you should buy it. You will need some computer reprogramming.
Old Mar 25, 2009 | 01:20 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
will my existing set of Hooker 2055 headers work?
Old Mar 25, 2009 | 02:51 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
yep.
Old Mar 30, 2009 | 07:51 AM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
nice set up for a good price! i need 2000 bucks lol
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
6998poncho
Sep 25, 2015 02:56 PM
