need some advice!
Old Apr 14, 2009 | 12:49 AM
shadowknight's Avatar
Car: 89 rs
Engine: 305 tbi
Axle/Gears: stock
need some advice!
ok to start with ive got an 89 rs with the plain jane 305/700r4 set up and im wantin to step it up a little bit. its got a straight body with only one med. sized dent in the pass. side fender, so to me its worth fixin up. i was thinkin about doin a mild 350 tpi build up with the following parts.
Item# 350-3870
Item# 350-3860
in also wanting to upgrade the valve train but im un-sure on which parts to use. im going for torque more than horsepower. i was also thinking about the vortec fast burn heads but thats just an idea.
also i was wondering about transmissions. im wanting a manual, but the question is a t5, or t56?
then comes the question of rearends. i was thinkind about a 4th gen with disc brakes and a 3.73 gear ratio and an aluminum drive line. all opinions will be taken into consideration.
Old Apr 14, 2009 | 03:22 PM
Car: 89 rs
Engine: 305 tbi
Axle/Gears: stock
Re: need some advice!
no one??
Old Apr 14, 2009 | 03:52 PM
NemeSS-TyranT's Avatar
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
what is your primary goal? drag, street, weekend,etc?
Old Apr 14, 2009 | 05:43 PM
Car: 89 rs
Engine: 305 tbi
Axle/Gears: stock
im wantin a weekend pavement pounder with a fairly descent amount of power. nothin too radical, i wanna send all the little hondas home cryin with their tail between their legs
Old Apr 17, 2009 | 12:42 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Forget the T5.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
