Just curious/ Track and Dyno Numbers
Old Apr 29, 2009 | 11:19 AM
Z28 Rida's Avatar
Car: 92' Z28
Engine: 406
Axle/Gears: 3.23 Posi
I have a 92 Z28 with a stock rear end, stock 700r4 transmission, and im building a 406 sbc to put in it. It has a zz409 hydrolic roller tpis cam, summit brand vortec heads, forged pistons,5.7" rods, TPIS big mouth intake, SLP intake runners 24 lb. injectors, holley 58 mm throtle body, Comp Cam 1.5 roller rockers, hydrolic roller lifters. just lookin for some input on what people think i can get out of this motor on the track and the dyno. Any advice or sugestions would be apriciated also.
Old Apr 30, 2009 | 01:43 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Just curious/ Track and Dyno Numbers
Which TPIS cam? There is no ZZ409 that I know of, unless I'm forgetting something? Did you mean the ZZ9? If so, that's a small cam for a 406. One local member built a 406 with a Comp XFI280HR-113 camshaft, and made 403 RWHP with a SuperRam intake.
Old May 1, 2009 | 09:36 AM
Z28 Rida's Avatar
Car: 92' Z28
Engine: 406
http://tpis.com/index.php?module=cat...draulic+Roller
this is a link to where i bought the cam.
the specs are
ZZ-409 Hyd Roller:
Advertised Duration 287/287
Duration @.050 226/226
Gross Lift .520/.520
Lobe Seperation 112
Old May 1, 2009 | 12:07 PM
madmux's Avatar
Car: 89 rs
Engine: 69' 396 .030 over
Transmission: turbo 350
http://www.speedwaybids.com/tech/ezonlinedyno.html
i use this site. very helpful, not %100 on accuricy but i hear good things. hope it helps
83RDRACR
Mar 26, 2016 08:13 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Doobie52
Sep 11, 2015 06:19 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
