Need help
Old May 19, 2009 | 03:33 PM
arizonacamaro's Avatar
Car: 1987 Chevy Camaro
Engine: 2.8 V/6
Need help
Hi I need help ok iam tryin to put a 1996 Chevy Silverado 5.0 into my 1988 Chevy Camaro but i was just wondering if it would fit
Old May 19, 2009 | 04:20 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Need help
Yes, physically the engine will fit. However, it won't bolt to your transmission as the bellhousing pattern is different. You'll also need to figure out what you want to do to get air and fuel into the engine. Are you going to swap the EFI into the Camaro as well? Or are you planning on swapping to carb? Both have their advantages/disadvantages but both will work.
Old May 19, 2009 | 04:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
Read the V6 to V8 swap sticky in the top section of this forum. That covers the basics.
A '96 Silverado would be a Vortec engine, I believe. Not a very performance-friendly EFI system.
Old May 20, 2009 | 12:03 AM
Engine: 2.8 V/6
Re: Need help
ok thank for the help I have the motor,tranny and the wirring harness iam mean every thing but i just wanna know if all of it would bolt up? would i have to change any thing like motor mounts or axles?
Old May 20, 2009 | 07:58 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Re: Need help
The engine will be fine, it should fit the motor mounts with no problems. What transmission do you have? Is it from a 2 wheel drive or a 4 wheel drive? 4 wheel drive transmission won't fit, the tailhousing is different. If its a 2 wheel drive transmission, you would have to measure it to make sure its the same length as your 700R4. Should be close. The only other issue would be the torque arm mount. The torque arms on these cars mount to the transmission tailhousing. Your truck transmission wont have the provisions for this so you would need to get a torque arm relocation kit. You can find them online and from the various site sponsors to relocate the torque arm mount from the transmission tailhousing to the crossmember.
The wiring harness may need some modifications like lengthening some wires, or splicing directly into the Camaro's wiring harness to work. You do have the ECM from the truck, right? The transmission if its original to the truck and an automatic will be a 4L60E and it will need to have the truck's ECM to control it.
Also, you will need to do some plumbing for the fuel lines as you're going from the v6's MPFI to the truck's SFI. The fuel lines in the truck would have come up from behind the engine IIRC, whereas your fuel lines will come up the side frame rail and then over across the top of the front of the engine.
Old May 20, 2009 | 03:55 PM
five7kid's Avatar
Originally Posted by arizonacamaro
... i just wanna know if all of it would bolt up? would i have to change any thing like motor mounts or axles?
Read the V6 to V8 swap sticky.
Relocating the torque arm mount isn't a bad idea, but it isn't the only choice. If the Silverado is 2WD, the tailshaft housing from the V6 transmission should transfer over to the V8 transmission.
I can't imagine using the truck EFI system. But, then, I am sometimes short on imagination.
Old May 20, 2009 | 05:21 PM
Engine: 2.8 V/6
Re: Need help
HI i need to know if i need to keep my wirring harness or not? also how much should i sell my Motor and Trannsmission for? also i have the A/C system lokking to sell it to but dont know how much to sell it for? everything works the motor is a 2.8 v/6 motor and the tranny is 700R4
