can I run lt1 tank/pump on tbi car?
I have got a tbi car that will later be a lt1 swap or maybe a lsx? I need to swap the pump because its dead...my question is since I plan on later doing a swap can I get away with swapping the complete tank and fuel pump assembly (from a 95lt1 car)? I did alot of search before asking this however i could never get a straight answer...This is a bone stock tbi car with stock fp regulator on it..I would presume I need to replace the fuel line in the back to some FI's? but will it work w/o jacking everything up? My friend has offerend the tank so it would be a good time if it works..
I hate working on the fuel tank....intank fuel pumps suck..
anyways thanks for any and all help...
Transmission: 4L80E/4L80E
It can be done. I'm not sure there's any advantage to replacing the whole tank, though. Why not a replacement like a Walbro 255? It'll handle any of those configurations.
1992 Trans Am
Aug 8, 2015 08:16 PM
