Front and Mid-plate help
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Front and Mid-plate help
I don't use a mid plate and I made my own front plate. You'll also need an engine limiter to keep the engine from moving forward and backward as the plates will flex without one.
Shagwell uses a midplate but he's done some custom fabrication to get it in there.
You can buy motor plates from vendors like Jegs or Summitracing. All need to be cut to fit.
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Front plate is pretty easy to fab up and mount. If you are going to run a mid make sure you have the headers as there is some trimming involved to the mid plate.
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
