L98 (1986) into 91 Z28
Old May 28, 2009 | 02:09 PM
Burbo's Avatar
Well I got this Deal (????) I't a 1991 Z28 with a 1986 5.7 TPI and trans from a Corvette. Anybody have any problem with this set up ?? I looked around and couldn't find any one who had the say set up. Do i need to change the oil pan or can i just get some one to do some custom exhaust work to get the pipes to fit?? Also any ideas on the cross member for the trans mount I seen in JEGS that they sell uni fits , But not to sure about that
Thank for any and all your help
Burbo
Old May 30, 2009 | 10:29 PM
87_355ci_Camaro's Avatar
Car: 86 Iroc-Z
Engine: 310ci soon to be 355ci
Transmission: built 700r4
Axle/Gears: I think 3.08s
Re: L98 (1986) into 91 Z28
Umm is the motor and trans in the car? I dont understand what youre asking.
But if it is out I can tell you there is a difference in the fuel lines for the tpi, Corvette had them on the passenger side, thirdgens had them on the drivers side. The trans will bolt up to the car with no problem if its a auto, if the car was a V6 with the 200r4 then I think your gonna need the crossmember from a v8 camaro plus the torque arm in the camaro mounted to the trans. But more info on what youre asking would help too.
Breazlan
Sep 25, 2015 11:20 AM
Z28camarokid
Sep 9, 2015 11:59 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
roysatikas
Sep 7, 2015 08:08 PM
Jackrabbit501
Sep 2, 2015 09:14 PM
