milkey oil fml
Old Jun 8, 2009 | 07:21 AM
ngonnelly's Avatar
Car: 1990 Camaro IROC-Z28
Engine: 5.7L 350cid
Transmission: auto
Axle/Gears: i think 3.42
milkey oil fml
yea so i just put in a 350 timed it and everthing and now its under each valve cover its got milkey oil blown head gaskit or intake manafold not on proply bc its in both heads and does any one know if this is the rite way to tighten the tpi intake manifold is first the 2nd from the front then all theway back that side then the other side the same way that what the hayins for my car sead i was thing maybe it was incorrect idk
Old Jun 8, 2009 | 07:10 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: milkey oil fml
The torque sequence probably isn't your problem. Pressure test the cooling system and find out where it's going.
Old Jun 8, 2009 | 08:01 PM
ngonnelly's Avatar
Engine: 5.7L 350cid
Transmission: auto
Re: milkey oil fml
you sure its not the bold pattern bc iv got my mec tellin me it is but ill def tell him to pres test the sys and stuff thanks
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
