Quick Question
Old Jun 29, 2009 | 12:10 PM
87cam's Avatar
Car: 1987 Sport Coupe
Quick Question
I have an 87 v6 2.8. I am looking to swap in a 350 tpi from a parts car. I know the ecm and everything needs to be changed over and my original plan was to go with a 350tpi parts car from 87-89 but i have a chance to pick up a 350tpi 92 z28. Will the ecm, and everything else be possible swap or will there be complications becuase of the changes made from these years?
Also did they make a 92 Z28 350tpi 5 speed or only 350tpi with auto trans?
Old Jun 29, 2009 | 12:16 PM
Stephen's Avatar
Car: 87 GTA
Re: Quick Question
350=auto only......Ever (in 3rd gens).
As for your early V6 to late TPI 350 swap.....
Your gonna have a lot of wiring differences to tackle. V6 to V8 unsuccessful swap
Old Jun 29, 2009 | 01:05 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Quick Question
Although many have done the conversion and made the T5 survive, GM never put the T5 behind a 350. The biggest engine that got the T5 was a 305. GM knew the transmission wouldn't be reliable behind the power of a 350.
It all depends on how you drive.
Old Jun 29, 2009 | 01:08 PM
The Devastator's Avatar
Car: 1992 Camaro RS
Engine: 8.0:1 454/Mild Hyd roller/Accel DFI
Transmission: WC T5
Axle/Gears: Stock 1992 open 7.5" 2.73 ratio
Re: Quick Question
I've converted three cars from TBI to speed density 90-92 TPI, and a TBI 4.3 to 350TPI. I've never done one of these v6s. Separating the Engine harness from the chassis harness wasn't insanely difficult with good wiring diagrams. Just don't expect to do any of this under any kind of time constraint. It could be done in one weekend with experience and good help but I would just get some good diagrams and take it nice and slow.
Old Jun 29, 2009 | 01:56 PM
87cam's Avatar
Re: Quick Question
I forgot to add. I will not be doing the work at all, there is a garage who will be doing the swap for me. So you guys would recommend finding an 87-89 camaro 350tpi parts car rather than the 90-92 or since i am not doing the work would you recommend going with the 90-92?
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
