TPI to Carb swap, oil pressure gauge wiring, tan wire?
Car: 86 IROC
Engine: SC'ed 350
Axle/Gears: 4.11 12bolt
I'm wrapping up a TPI to carb swap on my 86 IROC and can't seem to locate the tan wire for hooking up the oil pressure gauge (non stock sender). I completely removed the TPI harness (without cutting woo hoo) and have everything else wired. Is this elusive tan wire on the TPI harness? I read some posts where it's grouped with an orange and tan/white wire for the fuel pump switch. My shop manual just shows the tan wire from the sender to the gauge.
Transmission: 4L80E/4L80E
Should be E5 in the C100 connector. It is in the years before & after.
http://www.team3rdgen.com/modules/3r.../1987_c100.gif
http://www.team3rdgen.com/modules/3r.../1985_c100.gif
http://www.team3rdgen.com/modules/3r.../1989_c100.gif
Car: 1992 RS camaro
Engine: chevy 350
Axle/Gears: 3.73 axle
Re: TPI to Carb swap, oil pressure gauge wiring, tan wire?
i just did a v6 to carb v8 swap on my 92 camaro, the orange wire is hot and the grey wire goes to the fuel pump but double, so the third wire goes to the gauge, double check by looking at the engine control wiring harness for a 92 3.1 liter camaro. i believe that the tan wire is for the gauge.
Car: 86 IROC
Engine: SC'ed 350
Car: 1992 RS camaro
Engine: chevy 350
i see, i just used the old gauge and sensor, it works perfect for my car, except i needed a little brass extender because of my eldelbrook intake
Car: 86 IROC
Engine: SC'ed 350
I left everything on the 305 and pulled the TPI harness. I'm putting in a crate mother with all new sensors etc. These wires are on the TPI harness so I guess I'll have to find it under the dash.
86IROC112
Aug 17, 2015 02:00 PM
