Kickdown linkage ??
Old Aug 7, 2009 | 11:21 AM
Reapers88RS's Avatar
Car: 2x88 Camaro RS and 95 Grand AM
Engine: LG-3 305CI/400Ci GM 3100 V6
Transmission: 700R4/TH350
Axle/Gears: 3.08 10-Bolt/3.42 10-Bolt Posi
Kickdown linkage ??
My 3RD Gen has had a transplant from the 2.8L V6, 200R4 AOD to a 1977 305 w/ TH350. He used a weiand stealth intake and an edelbrock 1405 carb. Car takes off like a dog, but it also has no passing gear. Is this combo supposed to have a kickdown cable from the tranny? If so, how do I install it?
Old Aug 7, 2009 | 02:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's supposed to. Is the cable on the transmission? If so, you need to mount the cable housing to a bracket mounted to the intake manifold, and the cable end to the carb on the throttle arm opposite from the throttle cable (bottom side of the throttle arm).
Old Aug 7, 2009 | 02:24 PM
Re: Kickdown linkage ??
Cable isn't there. I'll have to pick one up from Ecklers for $30.....
Old Aug 7, 2009 | 05:23 PM
one92rs's Avatar
Car: SOLD!!!!!
i thought that a th350 was a vacuum operated tranny/. there is no tv cable on it at all.
Old Aug 9, 2009 | 01:49 PM
Can you give more info ??
Old Aug 9, 2009 | 02:07 PM
After some research, the vacuum modulator valve controls the upshift and the "Detent" or kickdown linkage controls downshift in WOT conditions. I will locate and install one ASAP ...
budowski
Carburetors
Oct 2, 2015 10:16 AM
mfp189
Sep 27, 2015 09:25 AM
IROCNParts
Sep 24, 2015 10:50 AM
Magman
Sep 14, 2015 01:30 AM
tonys91rs
Sep 2, 2015 07:07 PM
