Pre 86 sbc in a 92 camaro Z28 need help!!!
Old Aug 29, 2009 | 09:43 PM
92z28camarokid's Avatar
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
I am looking at getttin a carburated 350 that is a pre 86. I had some quiestions on if I could swap all the acessories from my 350TPI to the new engine?
I need help please
Old Aug 29, 2009 | 10:51 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Pre 86 sbc in a 92 camaro Z28 need help!!!
You should swap the heads and cam and TPI while you're at it probably.
But yes, you can swap that over as long as it's a 1970 or so or newer 350. The older heads dont have the threads for the accessory brackets on the front I dont think. Like some of those overhyped "camelhump" heads.
Old Aug 29, 2009 | 11:34 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You'll need a different flywheel as well - or maybe just a different starter - someone that remembers better can chime in (my old brain can't remember)
Old Aug 31, 2009 | 12:18 AM
jugheads88gta's Avatar
Car: 89 camaro
Engine: 68-454,87-nothing yet,88gta-305 tpi
Transmission: stock 700r4
Axle/Gears: borg warner 9-bolt/3:27 gears
i have an 88 camaro it was a v6 so i got a 92 305 for it had it in for a while that motor blew up so i swaped a 69 350 4 bolt in ever i used the starter and fly wheel off the 305 and also i used all brackets off 305
Old Aug 31, 2009 | 09:27 PM
Axle/Gears: stock
It turns out that my collision repair teacher knowsw a guy that has an LT1 out of a camaro z28 and i might be gettin that for 300 then throwin an eldebrock LT1 carb intake on it and a holley performer 750cfm
Old Sep 1, 2009 | 06:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Why not keep it simple and get the entire LT1?
This carb on Gen II/III engines stuff just baffles me.
Old Sep 1, 2009 | 09:05 PM
Axle/Gears: stock
Honestly I am done with fuel injection. Unless its a new car or an LS1 she's gunna be carbed. But it turns out the LT1 I was hopin to get was sold and now its runnin in a stock car the town over.
And I might even put a carb on an LS1 if I was to get one, a friend of mine might do it on his "modified" firehawk.
PS: the car will out run a procharged fox body with a 5.0 cobra engine.
Frozer!!!
Jan 19, 2024 04:55 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
GVMV
Aug 16, 2015 08:01 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
