700R4 with a 396?
Old Sep 8, 2009 | 07:54 PM
camille83's Avatar
700R4 with a 396?
Ok so the bellhousing should line up without an adapter? My 305 had a flexplate that had 3 holes to be bolted onto the converter, so if the flexplate in a 396 doesn't have the right bolt pattern, will I be able to take the flexplate off of my 305 and use that instead?
Old Sep 9, 2009 | 09:39 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 700R4 with a 396?
They're all 3-bolt, all 120 degrees apart. The issue is that there were 2 different distances from the crank centerline out to the converter bolts.
The 396 is sure to have the larger version, while a 305 Camaro converter has the smaller one. You can't use the 305 flexplate because it has a 153-tooth gear for the starter, while big blocks must use 168-tooth. You'll have to stay 168 tooth because of the starter. If they don't match up, you have a few options, with the correct one being the most expensive. The "wrong" way involves drilling, washers, and longer bolts, while the correct way involves buying a new flexplate.
Old Sep 9, 2009 | 11:43 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Dual pattern flex plate & 153//168 tooth starter?
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
