LT1 coolant hoses
Old Oct 21, 2000 | 05:11 PM
92TAConv's Avatar
LT1 coolant hoses
I am thinking of swapping in a carbed LT1. Will the radiator hoses connect the same as with a conventional small block, since the LT1 has reverse cooling? Will the accessory brackets off of my 92 work, or do you need the LT1 pieces? Thanks
Old Oct 23, 2000 | 10:07 AM
GhoSSt's Avatar
Yes, but you'll have to get a set of F-body LT1 hoses and use your stock radiator.
(Easy way) You'll need a set of B/F-body accy. brackets, a set (7) of 17mm spacers,
a Y-body (Vette) LT1 balancer and you'll be in the money.
Kelly 'GhoSSt' Rosato
1996 Impala SS, 383 LT4 (14.65 up here, 13.24 lower)
1984 Firebird, +.060 350 (Vortech Heads, HOT Cam, and schtuff)
1993 Caprice, 5.7 TBI (stock . . . FOR NOW)
"And if you wrong us, shall we not revenge? Revenge. The villany you
teach me, I will execute, and it shall go hard but I will better the
instruction."
Shylock in Act III, Scene I of 'Merchant of Venice' by William Shakespeare
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
