LT1 A/C clearance
Car: `86 SS / `87 SS
LT1 A/C clearance
Just wondering if anyone could comment on the A/C compressor clearance on a swap into a third gen.
Thoughts I thunk of
A non stock (for either application) PS motor mount moved back on the crossmember, using the extra mounts built into the LT1 block
A compressor that's "thinner" front to back.
Also, is there a way to make the A/C clutch slightly smaller in diameter?
TIA
matthew
Thoughts I thunk of
A non stock (for either application) PS motor mount moved back on the crossmember, using the extra mounts built into the LT1 blockA compressor that's "thinner" front to back.
TIA
matthew
what I did was leave the original compressorr and just notch the frame and weld in new metal. only took about an hour and you cant even see it. only problem with doing it that way is you have to get new lines made to clear the crossmember
-'92 RS with self-installed '95 LT1
-Heddman Headers
-TPIS throttle body airfoil
Kills
-'97 Mustang Cobra
-'98 V6 Camaro
-'89 5.0 ****stang
-'97 Sebring
-'96 ****stang Cobra
Losses
-'99 Mustang GT
-'96 Mustang Cobra
-'95 Z28 (good race)
-Heddman Headers
Kills
-'97 Mustang Cobra
-'98 V6 Camaro
-'89 5.0 ****stang
-'97 Sebring
Losses
-'99 Mustang GT
-'96 Mustang Cobra
codeysabatini
Nov 10, 2015 04:07 PM
2012sergen11
Oct 13, 2015 07:38 PM
