355 swap/switch
Old Oct 7, 2009 | 04:09 AM
nevertheless's Avatar
355 swap/switch
so i've got a nice 4-bolt 355 out of a truck (a 96 i think) all lined up to go in my 82 z28 with the stock 4 speed.
i WAS gonna get a 5 speed to swap in at the same time, but i cant find one of the later year models after they sorted out the issues. so im stickin with the 4 speed. anyways. . .
my question is whether or not the bell housing/etc will likely present a fitment issue. it seems to me like everything should be fine since its essentially the same shortblock. yes, no? thanks guys!
Old Oct 7, 2009 | 12:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No bellhousing mounting problems.
I'm not as sure about the 4-speed, but I believe you need a 153-tooth flywheel, and your '82 flywheel will not fit an '86-later crank. Get one for the '86-'92 f-body V8 manual transmission application and you should be fine. The clutch will still need to be for the '82 4-speed, though (at least the clutch disk).
Old Oct 7, 2009 | 04:54 PM
Re: 355 swap/switch
oh ok. i already have the correct flywheel. so i shouldnt NEED to replace the clutch. probably will anyway. . . im so stoked
Old Oct 8, 2009 | 09:42 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 355 swap/switch
Being as your '82 wasn't the hydraulic clutch release, it's more important to keep the engine from rocking too much. I strongly suggest you get a pair of ploy motor mounts from Energy Suspension. Or at the very least get new stock rubber ones. They're a pain to change, but not as bad as a binding clutch linkage. You'll also want a new pivot ball to screw into the '96 block, instead of just transferring the worn one off your old engine.
codeysabatini
Nov 10, 2015 04:07 PM
darwinprice
17
Oct 11, 2015 11:51 PM
mike22115
Sep 28, 2015 04:49 AM
BLK87Z
Sep 18, 2015 11:29 PM
anesthes
Sep 18, 2015 12:34 PM
