mild 327?
mild 327?
I figured this would be the best place to get an expert opinion on this. I was originally planning on swapping a 350 in my car in place of the stock LG4. I have a T-5 and I would like to keep that, so I am a little worried that the torque from a 350 would be too much for it. I am thinking a 327 would be a good idea now because it is a higher revving motor, with a little less low end torque. I am building a new motor, so I can set it up any way I want. I would like to go for around 275-300HP and about 300Tq, with some decent high RPM power but also decent idle and lowend. Can anybody give me suggestion on what type of cam, etc I should use to get these numbers? I will be using the stock Q-jet and distributor. I also have 3.73's, if that helps. Any help would be greatly appreciated.
Transmission: 4L80E/4L80E
You can certainly build a 327 to meet those performance objectives. But, your T5's fate would be about the same as it would behind a 350. The difference in life would be statistically insignificant.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, WP 305 heads ported & polished, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
[MN] S&W 8 point rollcage
FueledSoul
Sep 30, 2015 09:18 PM
84 TA NV
Sep 6, 2015 08:02 PM
