electric fuel pump
Old Feb 26, 2001 | 09:27 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
electric fuel pump
my camaro was originally fuel injected and i left the stock fuel pump. now i have a few questions as to what to do with it as far as power for the pump goes. someone told me to wire it to a switch in the dash (which would make an awesome theft deterent system). then someone told me to do it to the oil pressure sending unit (which would be alright except for the fact i can't find the wire and didn't think about this problem when i did the motor swap and i hace no idea how to read the schematics in the haynes manual). then someone told me to run it off the power wire for the distributor which sounds like a good idea to me. my question is would it be ok to run it off the power wire for the distributor?
if its not then screw it i'm just going for the switch idea because i gave up on finding the oil pressure switch. thanks for any help.
LONG LIVE THE MUSCLE CAR!!!!! MAY ITS REIGN NEVER END
1983Z28 350w/ edelbrock performer RPM power package with 64cc aluminum heads, flowtech shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust systemm, ASCD SS hood, 16" IROC rims.
future mods:
completely done over suspension, black paint with flames, B&M shifter, dakota digital gauge package, procharger supercharger.
Old Feb 27, 2001 | 01:17 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
You must not have looked very hard for a switch. I found it in about 10 seconds in a Jegs catalog.
First off, don't ever run an electric fuel pump without some type of safety cutoff tied to the engine! Second, you can wire it many different ways, but you will still need to use a relay. OK you don't have to, but I wouldn't do without one.
I use an oil pressure switch from Holley. The Jegs part number is 510-12-810 and is ~$25 phone number is 1-800-345-4545. You can connect it to any of the plugged oil ports on the lower side of the block. I connected mine to the first one on the driver side.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
www.koolmeister.com
Old Feb 27, 2001 | 02:38 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
no i wasn't looking for a new one i was looking for the connection for the existing sending unit in the chasis harness
future mods:
Old Feb 27, 2001 | 05:11 PM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Sorry - thought you were looking to buy one.
Miles
88 427 Camaro
www.koolmeister.com
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
