can a LT1 be put in a second gen and be carbrated?
Old Mar 8, 2001 | 08:45 PM
joe88gta's Avatar
Guys a might be buying a LT1 for short money and it is complete except for the intake manifold and up. I need to run it carb not FI. Can this be done? Is there a manifold for this? I also need the front of the motor components , pullys , blancer , water pump , alt. , things like that . Are the different than a normal small block? Or could i use any parts for an older motor? HELP
Old Mar 9, 2001 | 07:49 PM
mrls199's Avatar
Good news, sort of... first, try ZOOPS and march Performance for brackets. They have several brackets available for custom installations. Also, to my knowledge a Corvette 1992-1996 bracket set works well (assuming you can find/afford one) as for intakes, GM performance parts has a 4Brl non egr dual pattern intake. i think its around $200. Pace, SPDC, and others sell them online. Hope this helps. Oh yeah, zoops is online at http://www.zoops.com and March at http://www.marchperf.com
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
