Fuel Pump Question
Old Oct 30, 2009 | 02:43 PM
19Chevrolet84's Avatar
Car: 1984 Berlinetta,'82 and '86 Camaro
Engine: Rebuilt 350
Transmission: Automatic. =[
Axle/Gears: Stock
Fuel Pump Question
I'm swapping from a 2.8 to a 350... The guy I was talking to was under the impression that you can just run a mechanical fuel pump... Is this true? or do you need to mess with the old fuel pump in the tank?
If already posted please link me.
Old Oct 30, 2009 | 04:04 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Fuel Pump Question
what are you doing for fuel? carb, tpi, tbi, ? Will make a big difference
Old Oct 30, 2009 | 06:49 PM
Engine: Rebuilt 350
Axle/Gears: Stock
sorry, carbed 350... I believe the engine is from a 78 Chevy? not exactly sure... the only thing stock is block and the pistons.
Old Oct 30, 2009 | 07:33 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
depends on what type of pump is in the tank-port
injected engines have a two-stage turbine/roller pump
as stock-you cannot pull fuel through these without
running the pump.TBI and CFI use a two stage turbine
pump-you CAN pull fuel through these with the pump
inactive(done it)Certain carbed engines have a low
power single stage turbine pump-no regulator needed.
F/I pumps can be used with a regulator to feed a carb.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
