Electric fuel pump swap
Old Mar 26, 2001 | 03:54 PM
Cornflakekid's Avatar
I'm in the middle of my V6 to V8 swap.
I have the motor and tranny in and the drive
shaft hooked up (went pretty smooth after
changing the motor mounts, still cursing that
obstacle). Here's the problem, I wanted to drop the fuel tank and pull out the electric fuel pump and use a mechanical one. However, now I'm having second thoughts. What do I need to use the electric pump? The engine will use a road demon carb (91 RS Camaro).
Old Mar 26, 2001 | 07:48 PM
89V6toV8's Avatar
Get a Mallory 3-port adjustable regulator (65 psi - 5 psi) and use your stock pump. You can get a TPI fuel rail adaptor kit from ACCEL to go from your stock fuel line to -6AN fittings. This will allow you to utilize your fuel return line to help keep your stock pump lasting for a long time. Simple as pie
Old Mar 27, 2001 | 10:08 AM
Thanks 89V6toV8, I'll be ordering up the
parts this weekend.
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
