305....High or Low output???????
Old Mar 26, 2001 | 10:13 PM
idrag2's Avatar
So how can I tell if I have a low output or a high output 305??????
Old Mar 27, 2001 | 01:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Some wise guy is going to say all 305's are low output...
A little more info like year, induction type (carb, TBI, TPI) would be helpful, but, to answer your question: Check the eighth digit of your VIN - "H" = LG4, which should mean it has a single snorkle air cleaner and small exhaust, earlier versions also had lower compression; "G" - L69, which is the high-output carb version with dual-snorkle air cleaner and larger exhaust; "F" = TPI 305, which is higher power than a TBI - Manual transmission models had a better cam than auto versions, so also had more power. The VIN code for the TBI LO3 escapes me right now.
If the eighth character is an "8", you have a 350.
If I understand this correctly, only the L69 was called a "high output" engine.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, TBD heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Mar 27, 2001 | 02:16 PM
idrag2's Avatar
Hey thanks alot.....
The 8th digit is a E. Its TBI and its in a 89 Formula. 700R Tranny. What else do you need to know??????
Old Mar 27, 2001 | 04:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
TBI... say no more...
It's low output. There's no such thing as a high output one, it's not even like some are lower output than others. All the TBI 305s are the same, auto or manusl, very minor variations if any from year to year.
There were 2 versions of TPI 305s, and also of carbed 305s that were used in these cars. For those, the terms high and low output have meaning.
ICON Motorsports
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianI
Oct 3, 2015 12:57 PM
Giocio
Oct 1, 2015 12:20 PM
Damon
Sep 26, 2015 04:29 PM
6998poncho
Sep 25, 2015 02:56 PM
