Z28Boy, I have a ?
Old Mar 26, 2001 | 01:47 PM
PullmeoverRed's Avatar
Z28Boy, I have a ?
I went on your website, and I was looking at all of the things you bought with the new engine. As you know, I'm doing the same swap this summer, and I am going to get the 670 cfm Holley throttle body also. The part number that you gave said that it was for 5.7L 350's until 1989. Is this still going to work on the 350 HO?
Thanks man
Dave
Old Mar 27, 2001 | 06:44 PM
JPrevost's Avatar
Car: 91 Red Sled
You might not want to talk to just z28 boy. I just did the swap myself not even a week ago. The holley unit works fine but you will need to wire the injectors and the throttle position sensor. The throttle sensor/WOT is a BIG deal. I wired it up backwards and it was dumping fuel in at idle thinking I was at WOT. You'll need to pick up an adapter for the throttle sensor but when I'm done with the engine swap I should have the part you need and where to get it.
, Jon (350 TBI! I'll list mods when I have the time)
Old Mar 27, 2001 | 10:53 PM
Ok, I'm having a shop install it for me, so are they going to screw up because I forgot to buy small things like that? So far I'm sending them: Engine, vortec intake w/egr,holley 670 cfm throttle body, harmonic balancer, and that's it, Thats all I've heard that I need to buy new(can't reuse from 305)
Then I hear all this about keeping my old computer system and getting a new knock sensor, and now this throttle ****.
Can someone tell me flat out EVERYTHING I will need to send the shop so it can be done successfully?
Old Mar 27, 2001 | 10:55 PM
Also, JProvost, how do you like the engine? Was it worth buying and everything? How does it drive? Is it a complete makeover from the anemic 305?) I've heard it's great and worth it, but I want to hear it from someone who actually did it.
Thanks man,
Dave
P.S. My boss brought up a question that I hadn't even considered: Will I need a new transmission? I've got an automatic T-45 or whatever it's called and I've heard that they are good up to 400 HP. I'll buy gears when I get money after this choke of the pocket. Thanks
Old Mar 28, 2001 | 08:18 AM
JPrevost's Avatar
Car: 91 Red Sled
I don't have the time to tell you everything because I'm about to take off to go back to school. It's a 540 mile test drive and I'll tell you how she runs. Then I hope to have some time to right a tech article on the exact swap. Your trans should be okay as long as you don't race with it. I highly recommend a trans cooler, it'll save you hundreds in the long run. You might want to pick up a fuel pump block off plate. You can use the old one but it's usually all rusty. What intake are you using? If it's still going to be TBI then I can help you out a lot. You'll also need to modify the TV/cruise/throttle cable bracket but I'll show you how to do that.
, Jon (350 TBI!)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)
  • Holley 670 TB unit w/ 1/2" spacer/adapter
  • Edelbrock RPM vortec intake
  • 350ho 330hp vortec crate motor
  • 8" harm. balancer
  • Stewart stage 2 water pump w/160 thermo
  • SLP tri-y headers to full 3"
  • Rebuilt trans w/ SLP shift kit
  • Centerline 16x8's all around
  • 36/24 mm sway bars
  • Full poly bushings, even motor mounts
  • SLP LCA and panhard
  • Alston SFCs
  • Edelbrock 3 point STB
  • Global west steering brace aka wonderbar
  • Eibach pro kit springs
  • Bilstien high perf. struts and shocks
  • All this and I still have AC
My websiteAny questions?
fadetoblack
Jun 21, 2006 04:13 PM
burnouts4ever
Mar 13, 2003 01:25 PM
Z28 Boy
Aftermarket Product Review
Dec 14, 2001 10:45 AM
Z28 Boy
Nov 25, 2000 07:32 PM
