Pontiac 326: whats the scoop?
Old Apr 10, 2001 | 09:38 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Just curious : What are the specs of the engine...
http://kiztope.50megs.com
92 Rs 3.1/T-5
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14)
"If it can be better than it is, make it so!" Leon Calrinsky (00)
Old Apr 10, 2001 | 10:30 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
326 CID
made from about 63-66; little brother to the 389. It was the low-perf motor in the lineup, much like the 283 was to the 327 at the same time. The small motor came with a 2-barrel while the big one came with a 4-barrel.
I don't remember the bore and stroke and all that. I do recall that everybody that had one couldn't wait to yank it and drop in a 389 or later a 400. Sort of the LG4 305 of its day.
ICON Motorsports
Old Apr 10, 2001 | 11:21 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
thanks so far...
a friend of mine has one in his stock 67 tempest.... Are you sure about the 66 thing?
Old Apr 11, 2001 | 06:21 PM
88 Formula's Avatar
1967 was the last year. 326 Pontiacs are fine for cruising around but never build one. The bore is 3.72 and the stroke is 3.75. A Pontiac 400 also has a 3.75 stroke, but has a 4.12 bore. Pistons for 326s are hard to find and expensive compared to other Pontiacs. If you are going with traditional Pontiac power, then build a 400, 428, or 455. As a side note, did you know that there is no such thing as a big or small block Pontiac. All blocks from the 1955 287 to the 455s and even the worthless 301s are the same size. The difference being bore/stroke, journal size, and deck height.
Old Apr 11, 2001 | 07:38 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Thanks for the interesting info...
Anyone else have any extra tid-bits about it?
Linson
Oct 24, 2025 02:00 PM
mattcanty
Oct 12, 2015 11:08 AM
paul_huryk
Oct 1, 2015 04:27 PM
