383 build
Old Apr 23, 2001 | 12:16 PM
camaro6spd's Avatar
383 build
Ok, after some even further research on this build up I have decided not to do it(see "New old Idea...327". Problems with it bolting up to the T-56 and then whole problem of trying to get 350hp out of it on a student budget. Ok so lets see what comes up with a 383 buildup, ok the 383 is 350 block with a 400 crank right? So if I bought a 400 crank I should have a 383 or is bored some?? What is it gonna cost just to get the 350 to a 383? Any snags along the way? I can work from there to see if I can do it. i would still like to doa 327 but too much money to build up. It might still happen but who knows right...
Old Apr 23, 2001 | 01:13 PM
camaro6spd's Avatar
The Speed-O-Motive Budget 383 Kit Includes
  • New Nodular Iron Cast Crank
  • Clevite 77 Rod and Main Bearings
  • Sealed Power Cast Rings
  • Federal Mogul Cast Pistons
  • Reconditioned 5.565 conneting rods
Kit Upgrades
Moly Rings - 12.00
Hypereutectic Pistons - 40.00
Exteral Balancing - 95.00
400 Flex Plate - 28.00
400 Balancer - 68.00
My question is this If i have a 91 350, and a T-56 would I need the flywheel for the T-56 and a bancer, what of the extras do I need, has in it will not work with out it.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
83RDRACR
Mar 26, 2016 08:13 PM
Jorlain
Oct 8, 2015 01:57 AM
Mongoose462ci
Sep 16, 2015 11:46 PM
