Do GM make aluminum vortec heads?
Old May 25, 2001 | 01:13 AM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
My friend told me that GM makes aluminum vortec heads is that true or false?
Old May 25, 2001 | 04:28 AM
Slow Iroc's Avatar
There is no L31 aluminum casting that I am aware of, however the FastBurn is aluminum, uses the vortech intake pattern, and their price reflects it!
Old May 25, 2001 | 12:18 PM
BLOWN85/TA's Avatar
The GM fastburn head has both the standard chevy intake and Vortec bolt pattern. Edelbrock has aluminum vortec heads known as E-TEC 170 and 200. The 170 is better than the iron GM head and a good street head, but not a hi HP head like the fastburn. The E-TEC 200 is better than the Fastburn and outflows most the heads in it's categorey, but not the AFR CNC heads, CNC porting is hard to beat. The E-Tec's do have CNC port matching but are not CNC ported, yet. But at about $600 less than AFR I bought a set. These are the only "Vortec" aluminum heads I know of.
Old May 25, 2001 | 05:22 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Alot of people incorrectly call the Fastburn heads AL Vortec heads. I've even seen them advertised as such. Fastburns have several similarities w/ the Vortecs, but they are not Aluminum Vortecs.
The only Aluminum Vortecs are the Edelbrock E-Tec heads like someone already said. They're not made by GM though. However, for the price I think you'd do better to go w/ the TrickFlow 23 degree heads. They match/outflow the E-Tec 200 and are actually cheaper.
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
[This message has been edited by Ray87Z (edited May 25, 2001).]
Old May 25, 2001 | 06:03 PM
BLOWN85/TA's Avatar
Not on the flowbench I saw, the E-TEC 200 outflowed the G2 which outflows the 23º.
With the trickflows you also get the cheaper construction, which I think has been talked about enough.
Fastburn heads also contain the manifold bolt pattern for Vortec style manifolds as well as the older style.
Old May 26, 2001 | 03:00 AM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I am closeing thisa topic because it really has nothing to do with swapping motors. Next time please try the tech section.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
