magnaflux
Car: 1989 Camaro RS
Engine: LO5 350
Axle/Gears: 3.42 posi
magnaflux
i just got a 400 the other day and the guy said to have it magnafluxed and if it had a crack to bring it back to him and get another block but i was wondering how much mugnafluxing is? what is the highest that someone has ever had and what is the lowest? thanks Ty.
Last edited by Tyrel2018; Dec 13, 2009 at 09:48 PM. Reason: needed to change the title
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: magnaflux
Well, it is usually a package process, boil(clean), magnaflux(check for cracks), bore/hone, install cam bearings and freeze plugs.
All that usually runs me 220$ or so.
Think magging the block might be 80-100 since they will need the block cleaned to get it right, you can have no oil or grease on the block to perform this step.
Z
Z
gixxer92
Sep 1, 2015 04:32 PM
