how much for a 406?
Old Jun 9, 2001 | 12:28 PM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
how much for a 406?
well now that i am 100% sure im going through with my 406 TPI project i am wondering about price.
how much will it cost *counting block* to make the 406 *not counting heads and intake/TPI * so basically from oil pan to... pistons... i guess u can say. the reason i am stopping htere is because i already have the heads and tpi stuff. so im wondering how much *about* more i have left to put in. I want the pistons and crank to be forged and a desent cam *im trying to make about 500 HP*
anyone have a guesstimate?
Old Jun 9, 2001 | 01:36 PM
ImportsRsloths's Avatar
Check out EBAY.COM for awesome prices.... A lot of the stuff has warranties too!
Old Jun 9, 2001 | 04:52 PM
BigBlockJason's Avatar
Car: 1985 Z28
Engine: 502
http://www.allchevyengines.com/406-435.htm
BigBlockJason
85 Z28 T-Tops
http://communities.msn.com/JasonsStuff/homepage
Old Jun 12, 2001 | 10:07 AM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
you can get a used block for like $200, at least that's what i paid. Expect $300-$500 or so in block work, and musclemotors.com has an $829 rotating assembly for a 400 block including forged pistons, rods, and forged crank.
Then cam. You can go non-roller and pick virtually anything, but if you want to go roller cam, you'll need retro fit lifters, which adds another $300 or so to the mix. Anyway, the whole cam deal can be $200 - $600 depending.
Add an oil pump, oil pan, water pump, rings, bearings, and gaskets, and you're probably looking at around a $2500-$3000 price tag. I'm leaving out a lot of ****, because you said you have a whole top end already.
C409
Sep 23, 2015 04:30 PM
mddaniel
Sep 8, 2015 05:16 PM
trevor1010
Aug 26, 2015 02:41 PM
trevor1010
Aug 24, 2015 08:34 PM
trevor1010
Aug 24, 2015 11:29 AM
