Emissions and EGR, what exactly does it affect?
Old Jun 25, 2001 | 09:55 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I live in NJ which has the dyno. I just passed it with FLYING colors, and i didn't even do any prep work! I am planning on a 305 to 350 swap. If i build my 350 to mild/medium specs, will i be able to get away with still passing emissions? I know what EGR means, but when it is actually used? In cold start up? or constantly. If its only for cold start up, i could get rid of it and i would still pass... right?
  • 89 Formula 305 WS6
    SFC's, LCA's, Air Foil
    Spohn Panhard Bar
    Flowmaster Cat Back, Tranny Cooler
    A/F Ratio Meter (not a mod but it sure spurs interest)
    Trans Temp Gauge
    Most "Free" Mods
    3:73, Zexel Torsion Posi
  • 90 Eagle Talon 2.0
    (Winter Beater)
    Mods? Um, no
Old Jun 25, 2001 | 01:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It is there to surpress the formation of oxides of nitrogen. They are formed in high pressure and temperature conditions, which describe the combustion chamber pretty well.
The purpose of the valve is to "contaminate" the air/fuel mixture to lower the combustion temperature, particularly at low throttle opening. It is disabled at cold engine temperatures, and WOT.
The dyno test looks for NOX, so it's not a good idea to eliminate the EGR valve. Also, if there is a visual inspection, you'll fail if it isn't present or hooked up.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, LT MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
Old Jun 26, 2001 | 07:55 AM
Omega's Avatar
Engine: LS1 / LS3
Ok, thanks, i didn't know exactly when it was used. I just thought it was for quicker warmup when the engine is cold.
jaridjohn
Oct 5, 2015 07:01 AM
racereese
Oct 3, 2015 03:46 PM
djmarch
Oct 2, 2015 10:41 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
