Can anyone help me??
Old Jun 26, 2001 | 05:11 PM
LEADFOOT95's Avatar
Alright guys, here's the story: I have a '95 Camaro with a 3.4L V6. I blew the motor. It looks like the crankshaft went through the block . My dad seems to think that what broke was simply an aluminum cover but I'm thinking about the worst case scenario. Worst case scenario: I need a new engine. I really don't want to spend a couple of grand just to have the same engine. The 3.8L V6 uses the same drivetrain and motor mounts as mine. All that would have to be done is change the computer, radiator, and wiring harness and I found someone who would do everything for under 2K (engine & accessories included). Now, my friends were telling me that I might as well drop in a 350, but for that I'd have to change the tranny and driveshaft as well, not to mention the motor mounts . I don't have that kind of money. Another one of my friends told me why not put in a 305 instead which uses the same drivetrain (T5 tranny). My question is, does it use the same motor mounts? If not, then is there some way to adapt it while keeping things cost effective? Any ideas would really help me out...
'95 Camaro Artic White (DECEASED)
*Custom one-piece aluminum driveshaft
*Flowmaster 2-chamber muffler
*Hi-flo cat
*K&N air filter
*3.42 rear end
*GTS tailight blackouts
*Custom black brake light cover
*Custom black turn signal covers
*Custom black headlight(and high-beam) covers
*Artic white rims (nice!!)
Future Mods:
Buying an SS!!! (POSTPONED)
Old Jun 26, 2001 | 05:32 PM
Tas's Avatar
Tas
your friends are dumb putting in a 350 or 305 is the exact same amount of work. you have a v6 tranny you need a v6 engine to bolt to it. OR, your other choice: a 4.6L 300HP Cadillac Northstar engine will bolt to it. lots of HP not nearly the TQ of a LT1 350 so I think the tranny should handle it. You need to see if the 3.8L can even bolt right to your 3.4L tranny. I'm not sure if it will.
I was talking out my butt on the TQ numbers. I'll check them asap. LT1s have 325TQ I think, L98s had 345TQ.
Just checked. 4.6L caddy v8 has 295TQ
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
[This message has been edited by Tas (edited June 26, 2001).]
Old Jun 26, 2001 | 05:49 PM
LEADFOOT95's Avatar
The 3.8L will work. I just don't know if I want to settle for another V6.
Old Jun 26, 2001 | 05:52 PM
LEADFOOT95's Avatar
Oh yeah...I was told that the 305 runs off of a T5 tranny, which is what I have now. So I don't understand why you say that it wouldn't work ...
Old Jun 26, 2001 | 06:04 PM
Tas's Avatar
Tas
its bolt pattern to the block is different. that's gonna be the sticking point in your swap. You could try putting in a GTP supercharged 3.8L. now that I think more about it, the caddy DOHC might be too wide.
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
