carbed 305HO to 350TPI
Old Jul 9, 2001 | 11:49 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
hey im thinking about getttin a 350tpi outta a GTA.....what would i have to do to my car for the swap....should i change it over to tpi or put on the carb and intake that i have right now?
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
best E.T. (dont laugh) 15.997 @86.04mph
http://www.geocities.com/K_towngangsta
Old Jul 10, 2001 | 10:42 AM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Be advised this is not a plug and play swap. If the 350 TPI is 90 or newer, your firewall harness will not mount up without modification or switching to a 90+ dash (on Camaros, don't know about Firebirds). Plus, you will need to use an intank fuel pump and the needed hoses. Also the engine harness and computer harness could be one (90+, 89- is still seperate). I should know, I am going 305 E4ME A4 to 357 SD TPI WC T5. Plus I am contemplating switching my dash to a '90-'92, that way I can use the electrical speedo, which is needed for the SD 7730 computer to operate the FI.
George P. Lara
1984 Z28
2001 SS #0391
SCCA, SCFB, SC3GFB
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
