Do you have to remove the AC to fit a big...
Car: '89 Firebird
Engine: 7.0L
I believe mine would have cleared the AC assembly on the firewall if I had used standard valve covers. I used tall valve covers because I have roller rockers and the tall versions will not fit with AC still in the car.
If you put a big block in it, it would not be a street car most likely anyways. If you are going to do a big block, might as well go all out power on it, and in that case you wont want to drive it where you need AC.
You can get enough power from a small "black"
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I don't have a heater or AC in my car but like QwkTrip said. You need to use regular height valve covers to get it to fit. Tall valve covers will probably also interfere with the windshield wiper motor.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
I'llrocya
Feb 2, 2016 11:43 PM
