1992 305 to 1979's 350 with 461 heads
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
will the tbi bolt up to the 461 camel humps or is the bolts different. would like to swap to stealth ram but would like to know what all would need to be done first thanks.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 1992 305 to 1979's 350 with 461 heads
since you have TFS heads, forget the lame old 461 heads. Sell them to someone restoring an old car. Even fully ported, they can't compete with even TFS' 175cc heads.
Car: 1992 Camaro
Transmission: t-5
true but will they fit on an older style block.
Transmission: 4L80E/4L80E
If they fit a 3rd gen block, they'll fit any 1955-1981 block.
