LAY UM OUT
Car: 98 Camaro Z28
Engine: 346 LS1
Axle/Gears: 3:43
LAY UM OUT
I have a 383 stroker sitting in my garage. Bored 40 over sbc with 190 64 cc heads comps retro fit roller cam with tpis mini ram intake I am wanting to replace the stock computer? but dont no if this is hard, or simply unplug then plug in the new one. I was lookin at a holley computer and then a fast one. Now is there a performance computer that just plugs into the wireing harness? any answer would be appreciated thanks
Transmission: 4L80E/4L80E
There is nothing I am aware of that plugs in place of the factory computer. Most people reprogram the factory PROM.
Some have taken the LS1 PCM and adapted it to run Gen I SBC's. They typically discuss on the DIY PROM, DFI & ECM, or alternative EFI forums.
I'm not sure about FAST, but I don't believe the Holley is capable of controlling the torque converter lock-up function.
dbrochard
Oct 3, 2015 12:43 PM
the_hamturdler
Sep 22, 2015 02:59 AM
