Power Windows 92 T/A
Old Aug 14, 2001 | 03:02 PM
OldGunner's Avatar
? for you. I have a 92 T/A with power windows and recently the driver
window has been acting up. It will roll down (or up) halfway then I have to wait for several minutes and it will go another inch or two and so on. Its a real pain. Takes forever. My ? is could this be the motor wearing out or do I have a wiring prob? I'm not sure what to check to make sure. Any help would be appreciated
Old Aug 14, 2001 | 07:31 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Had the same problem as you. I kept putting it off hold and the longer I did the longer it took to raise and lower the window. Finally replaced the motor last month and works just fine now. Will replace the passenger side this month.
Old Aug 14, 2001 | 08:13 PM
OldGunner's Avatar
I've replaced a window motor on a Buick but have heard these F-Bodies can be a bear. Any tips?
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
