LS1 Internals!
Car: 1986 IROC-Z
LS1 Internals!
Is LS1 internals possible on a 350 tpi?
what would it affect?
what number could i expect to see over stock on the dyno?
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Re: LS1 Internals!
LS1 engines and SBCs are too different. Most parts won't interchange.
Car: 1994 Z28
Engine: 355 LT1
Re: LS1 Internals!
Don't know what you are calling an internal exactly, are we talking about rotating assembly or everything within the block? Either way nothing from a LS1 is really interchangeable, the LS1 and a 350 have different bores so pistons and rings are useless. Cam and crank aren't interchangeable.
Transmission: 4L80E/4L80E
Rod bearings and roller lifters are the only LS1 parts that will fit in a Gen I/II SBC.
