Dyno results
Old Aug 20, 2001 | 01:57 PM
Z28DJP1987's Avatar
Dyno results
Ran my car on Dynotek Chassis Dyno today.
Results:
211 RWHP and 264 HP @ flywheel
282 RWTQ and 352 #/ft @ flywheel
Fuel Pressure @41PSI and Air/Fuel Ratio 13:1
Not to bad for a daily driver, check profile.
1987 Black Camaro IROC-Z (original owner) Replaced LB9 @ 86100 miles.
New 350 Crate engine
Balanced & blueprinted
WP 67cc Heads 9.6:1 C.R.
Cam: 454lift,216dur@50,110ls
TPI Induction(from 305)
22# Fuel Injectors,AFPR&Gage
SLP Intake runners
New GM 1988 chip
K&N filters & Air Foil Hothkis STB
SLP 1 3/4 Headers
CATCO 3" Catalytic conv.
SLP 3" Cat Back Exhaust
700R4 Auto
SLP Torque Converter (2400 stall)
B-W 9 bolt rear 2:77 Possi. Four wheel disc brakes,245/45/ZR-17 Tires
17x8.5 ATI 5 Razze Wheels
Dyno results: 211 RWHP & 282 RWTQ.
264 HP & 352#/ft at flywheel. NEW TOY
[This message has been edited by Z28DJP1987 (edited August 23, 2001).]
Old Aug 20, 2001 | 05:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Not bad numbers you got there. Compare to a carbed 305...
https://www.thirdgen.org/messgboard/...ML/012689.html
I haven't run mine at the track yet, I'll post results when I do; you have times yet?
ICON Motorsports
Old Aug 20, 2001 | 08:03 PM
Z28DJP1987's Avatar
RB
Thanks, better then some of your comments.
I did beef up the drivetrain, sorry about the
2:77 ratio, but higher gears are getting hard
to find. If my old 305 TPI had your numbers,
I could have saved some money. :P:P
Old Sep 6, 2001 | 09:44 AM
Z28DJP1987's Avatar
RB
Dyno test was made with all Emission controls
installed and working.
World Prod SR 67cc Heads 9.6:1 C.R.
SLP Intake runners
New GM 1988 chip
Hothkis STB
SLP 1 3/4 Headers
700R4 Auto
264 HP & 352#/ft at flywheel with all emission controls installed. New Toy!
Falcon50
Aug 22, 2020 03:26 PM
LT1Formula
Oct 8, 2015 08:34 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
