What is the?
Old Sep 6, 2001 | 08:48 AM
Z28DJP1987's Avatar
What is the?
What is the difference in Horsepower between
a Carb intake and TPI system when used on the same 350 engine?
Old Sep 6, 2001 | 10:00 AM
Keith5's Avatar
Car: C1500
It probably depends on the specs of the 350 engine. I'd say the more agressive it is the more the carb will win out.
1989 Pontiac Firebird Formula LO3/700R4
-180 degree stat, Hooker Cat-Back, Wonder Bar
http://www.geocities.com/krt80/
Old Sep 6, 2001 | 11:21 AM
Z28DJP1987's Avatar
Engine remains the same,just changing the intake Carb to TPI.
Old Sep 6, 2001 | 01:04 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It depends alot on what's around it... if it's all well-matched parts to the particular induction system, the carb will smoke the TPI for HP, since the HP peak will occur several hundred RPM higher; the TPI may put up better low-mid torque numbers; as far as which would make a faster car, that would have alot to do with things like converter and gearing. The TPI would probably work better with poor gears and stock converter; the carb will shine with better gears and high-stall converter.
The bigger the cam and heads and exhaust, the more the carb will beat the TPI by. TPI has a very much fixed flow limit, without heavy modification or parts replacement, whereas it's a total no-brainer to get flow with a carb.
ICON Motorsports
