Crate ? Rebuild ? Lt1 ? what should i do ?
Old Sep 13, 2001 | 01:23 AM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
Hi, i was wondering if yall could help me out, effectivly this winter i want to do one of the following, but what sounds best for max hp. Should i rebuild the tpi with high performance parts, get a crate motor instead, or maybe shop around for a lt1?
(question 1) Suppose i went with the crate option, Could i get the zz4, and put the superram, runners, and just port my base to fit the runners, use all the stock computer harnesses, and add a supercharger ? Will that work with all stock emmisions, AC, other that the fact ill need a new ECU ?
What is the best option ?
Old Sep 13, 2001 | 03:22 AM
jijiandfarmgang's Avatar
Hey,
To answer the crate engine question. If you intend to supercharge you might as well build an engine for it (cam, forged pistons, lower compression). Although not necessary it would be a pretty good idea.
david068513
LSX and LTX Parts
Nov 15, 2015 11:37 PM
Giocio
Oct 1, 2015 12:20 PM
6998poncho
Sep 25, 2015 02:56 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
