Accessory brackets help
Old Feb 9, 2010 | 10:25 PM
bubba20189's Avatar
Ok i just finished my v6 to v8 swap and my brackets wont clearence the hood. Will lt1 brackets work or what do i need to do thanks
Old Feb 9, 2010 | 10:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Accessory brackets help
What brackets are you using now?
Old Feb 9, 2010 | 10:50 PM
bubba20189's Avatar
I am using the brackets that came in the c/k series trucks their about 3 inches too tall
Old Feb 9, 2010 | 10:58 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What year truck?
Old Feb 9, 2010 | 11:03 PM
bubba20189's Avatar
What year truck?
89 silverado. Do you kno if the brackets off a 1996 v6 will work with the 350 like the s10s do
Old Feb 9, 2010 | 11:11 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No. The S10's brackets will work because they're from a 90 degree 4.3L V6, which is basically a small block V8 with the back two cylinders cut off.
You'll need to find brackets from a passenger car application to put your accessories on. Some older truck setups might work as long as it's for a long water pump, but I don't know for sure.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
meeklay812
Oct 1, 2015 03:46 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
armybyrd
Sep 26, 2015 03:37 PM
